I don't do double posting normally of course but I have also posted this in building as I'm not sure where it sits.
Can I drill through the wall to the outside underneath the damp proof membrane to run a cable ?
It will be about 6 inches below the actual membrane layer so not damaging the membrane itself. It will also be about 6 inches off the patio surface as well. I have quite a high black brick as you can see before the membrane layer. Not sure if this location for the hole is allowed or will compromise the integrity of the damp proofing. It will be a vey small hole, around 10mm
