The better question for you is, realistically how much will it save? What are you thinking of putting in there, what will it's insulative value be, how does it affect the U value of the roof and hence what overall effect wil it have. You might find that it will cost you an extra 300 quid, and save you £20 a year on your heating bill. That's a 15 year payback
FWIW My daughter has had a very large dormer conversion done on her bungalow complete with £900 worth of Celotex installed (150mm?). It has led to the upstairs bedrooms getting too hot, because they have gone open plan including the stair case, so all the downstairs heat ends up in the upper bedrooms.
Frank
I have been trying to find out if there is any rule / calculation for how U values affect bills. So far, not discovered anything.
Is there a way of calculating the difference between 0.25 and 0.17 in terms of heating costs for a room that has walls with 0.25, smallish window (about 1m square), with about 15m square floor area?
My figures are for the improvement from .25 to .17So in other words, going from .25 to .17 will save you a little over half a pence per hour per 20 degree difference. If it's -15 outside you save nearly 1.5p an hour. If your heater cost is different to a simple electric heater then you must factor that in too
costs of energy
Where is your ventillation, is there foil faced insulation above the OSB layer, in which case how do you think your ventillation layer is going to work?
And how do brick purpends ventilate the area above the OSB, does it have a parapit wall detail?
