I had my gas fire removed and the wall was "plastered" up for painting.However it wasn't ready to just paint over and previous decorator added filler to level it out so it could be painted over.
It needed another coat and when applying the paint some bubbles appeared.Sadly they didn't go back down when dry.
Painter was just going to sand them down and repaint but after applying the second coat the bubbles got much worse and he was able to just peel away the filler!
The problem seems to be with the filler under the paint?
He is gonna come back and try and fill it again or he said he might have to add lining paper.
There is already lining paper on the wall,apart from the bit in the middle where the hole was plastered up that is causing the problems.
Will it be ok to add lining paper on top of already painted lining paper?
Any ideas are much appreciated.
Thank you.
