What header tank does a vented cylinder require?
20 Sep 2010
Argyll
I am looking at reworking our kitchen and ideally I would like to move the vented hot water cylinder out the cupboard and into our loft. This would have two benefits the cupboard wall can be knocked out and the space utilised for kitchen storage which we are short of.
Obviously being a vented cylinder I will need to raise the small header tank for the heating system which is fairly simple if I know what head is required?
I also need to clarify what is required in way of a header tank for the hot water side of the system and what pressure head it requires?
Minimum 50 gal / 240 litre tank
Its got to be well supported and have a marine ply base.
Buggered if I can remember the dimensions the tank base should project from the widest point of the tank itself though.
Just bear in mind that one litre of water weighs one kilo so do the maths...........
Glad I asked I was hoping I didn't have to raise the whole storage tank set up and could use a smaller additional tank for the hot water side only.........
Space is going to be tight in the loft with the big tank having to be raised is their a minimum head?
as high as you can. Minimum of 300mm from the base of the tank to the top of the cylinder.
You be better off having an unvented cylinder installed to be honest
Look at coffin tanks if space is tight - long and low so it might be more suited to your proposed installation
It's a solid fuel set up I put in. All works well with the vented system, nice and safe so don't really want to change. I will get the tape out tomorrow night and start looking at the coffin tank option as well. Thinking also about swapping the leak off radiator for a heat dump exchanger plate which I came across at some stage on the web. Dammed if I can find such a thing now though, looked a really neat fail safe solution.
