Can you please explain the process of how they will cap the live cable by preventing themselves from getting electrocuted?
Or even detached properties. When I moved to my last home in England in 1997 there was an overhead drop from a nearby pole to my neighbor's house onto the old-style bracket with individual porcelain insulators, a splice there for his service, then continuing across both of our front yards to a similar bracket on my house. A few years later my neighbor had a lot of work done on his house including moving to an external meter cabinet and having a new underground feed from the pole. The overheads were simply removed from his old bracket and reterminated at the pole to take up the slack. When I left, you could still see the old splice points on the cables, now mid-air over my neighbor's front garden.Sometimes a pair of semis will be on the same drop cable.
Indeed so, particularly with overhead supplies. Mine comes from a pole in a neighbour's garden. Only three cables leave the pole, to supply a total of 11 properties in my little corner of the village. The cables supplying my house also supplies the two neighbouring properties, but that's a bit of a cheat because all three properties were once (until about 65 years ago) just 'one'. However, that only leaves 2 cables from the pole for the remaining 8 properties (most of which, admittedly, are pretty small).Or even detached properties. When I moved to my last home in England in 1997 there was an overhead drop from a nearby pole to my neighbor's house onto the old-style bracket with individual porcelain insulators, a splice there for his service, then continuing across both of our front yards to a similar bracket on my house.Sometimes a pair of semis will be on the same drop cable.
As you say, all quite common with overhead supplies in rural areas especially. Where I lived there was all manner of short branches from the main distribution run to poles which then fed four, five, six more homes. The pole from which our drop came was sited about 100 ft. back from the main run on the road and fed with two phases plus neutral. My house, my next door neighbor, and I think the house next to him were all on one phase. The other phase then had runs around the back of our properties to the homes on either side of our group of three. There were other places where a single-phase branch would run to a pole situated between the backs of properties with about four drops from it - two homes on one road and two on the other.Mine comes from a pole in a neighbour's garden. Only three cables leave the pole, to supply a total of 11 properties in my little corner of the village. The cables supplying my house also supplies the two neighbouring properties, but that's a bit of a cheat because all three properties were once (until about 65 years ago) just 'one'. However, that only leaves 2 cables from the pole for the remaining 8 properties (most of which, admittedly, are pretty small).
Ah, I overlooked the phasesAs you say, all quite common with overhead supplies in rural areas especially. Where I lived there was all manner of short branches from the main distribution run to poles which then fed four, five, six more homes. The pole from which our drop came was sited about 100 ft. back from the main run on the road and fed with two phases plus neutral. My house, my next door neighbor, and I think the house next to him were all on one phase.
Aerial bundled cable? At my former home above they came out and replaced all of the distribution with it about a year before I left, as they were starting to get more and more faults on the network. One such had occurred a couple of years earlier: Suddenly had all the lights in the house flickering one windy winter night and heard massive arcing from outside, then all went quiet. It was only when I looked outside next morning that I saw the old cable head on the underground feeder to the overheads on the pole right at the front of my property had corroded away enough to fall from its mounting. I think I probably have some pictures in my archive somewhere....Ah, I overlooked the phasesThe "three cables coming from the pole" (serving a total of 11 properties) may well all be 3P+N.
