We have a pair of lights in our hall controlled by 3-way switching. Last week I replaced the existing CFL bulbs with LED versions to get more and instantaneous light when switched on. The house was fully re-wired in 2013 and certificated as OK by the installing electrician.
Last night I was woken by the two LED bulbs flashing like strobe lights. I thought at first the smoke detectors were flashing but no. The wall lights themselves were flashing about once per second. No other lights were affected. I loosened the bulbs to stop them flashing and all appeared OK. Today I switched off that lighting circuit for safety as we are away overnight.
What's causing this? Is it likely to be a fault on the 3-way switching? If so, what do I check/do? All ideas would be appreciated.
Thanks.
Thanks.
