gas fire removed
25 Aug 2004
Cornwall
i removed my gas fire to fit a new electric suite
the gas is off at the cock...whats my next step to make this safe
cheers
geof
You should already know what to do next as I presume you are gas safe registered as you have already started the job
you presume wrong...i had wondered if i would get this kind of answer
but you are right
That's the only answer you'll get on here I'm afraid. As an rgi I have spent a lot of time and money on training, assesment and having the correct testing equipment to work on gas. Giving diy gas advice would be like biting the hand that feeds me. See the diy gas thread at the top of the forum for more info
That's the only answer you'll get on here I'm afraid as an rgi I have spent a lot of time and money on training, assesment and having the correct testing equipment to work on gas. Giving diy gas advice would be like biting the hand that feeds me. See the diy gas thread at the top of the forum for more info
is the answer then go call in a gas engineer?...there is one coming to do the fitted kitchen hob but not for a week or so and i thought an intermediate step could be taken
cheers
geof
Hope he doesnt serve you with a RIDDOR for leaving an open ended gas supply. It needs to be plugged / capped and tightness tested. A closed control valve is classed as an open end.
As above, in the condition you've left it you could be reported to the HSE for leaving your gas supply in a dangerous condition. Get an RGI out to sort it ASAP and definitely before you use the electric fire. You don't know that there isn't a small amount of gas leaking into the new fire, which could explode next time you turn the fire on
cheers
geof
Dont light a match or use a naked flame for the next week, Oh and dont switch on any lights either,
Hope that answers your question.
ill look out for 'gas explosion' title in the west briton.
FIRE PLUG by mrcrow_uk, on Flickr
all done now...£30 and certified!!..my heating engineer lives close by
well worth it and sorry to disappoint
do you guys know anything about parachutes...:D
Preumably, that is in a non visible, or at least hard to see, position?
