Or you could be certain of complying with it by never using 1.0 sq. mm at all and using 1.5 as a minimum.It's not a question of disregard or comprehension - it is nonsense.
You can comply with it by picking whichever part agrees with what you want to do even though other parts may not.
Clearly the regulation as written was intended to permit 1.0 to be used for something involving lighting. But what? It's ambiguous as to what "lighting circuit" includes, and in the absence of some definition of "power circuit" which says it shall exclude whatever "lighting circuit" means, it's also contradictory since a circuit supplying power to lights is, by definition, a power circuit.So what's the problem?
How would you work out what the minimum permitted cable size is supposed to be if you had a circuit feeding one light plus five fans? Or five lights plus one fan? Or three lights and three fans?
