So you're saying, so long as the link from the DB to smoke 1 is in 1.5mm² I can then run my interlink in 1.0mm to the next x no of smokes? That's patently ridiculous.
If it's the typical 3-conductor (plus earth) of 240V units though, only one of the three conductors is being used only for signaling purposes. The other two are still supplying power to the other detectors down the line.
But I agree it's ridiculous to say that 1.0 sq. mm is perfectly fine to feed several amps' worth of lighting but somehow is unacceptable to feed power to a few smoke detectors drawing a fraction of amp in total (unless they happen to be on a lighting circuit, assuming by the vague definitions in that table that adding the smoke detectors doesn't mean that the circuit ceases to be a "lighting circuit").
