O.K., don't have to, but would like to!No, you don't have to!
Since the BS7671 table is clearly trying to make a distinction between a lighting circuit and a power circuit, it might be considered important to understand the intended meanings of those terms.
They're simple statements. Which word(s) don't you understand?
NOTE 4 In the UK, 1,0mm2 cable is allowed for use in lighting circuits.
NOTE 5 In the UK 1,0 mm2 copper cable is allowed for fixed installations utilizing cables and insulated conductors for power and lighting circuits.
Ignoring that we're not clear on the difference between a lighting circuit and a power circuit, and assuming that somehow the intended meaning is that the latter does not include the former, note 4 starts off clear enough if read by itself, inferring that 1.0 is the minimum for a lighting circuit and 1.5 the minimum for anything else (presumably a power circuit, whatever that may be).
Note 5 then seems to suggest that the U.K. allows 1.0 for both lighting and power circuits (but only if copper). But what are we supposed to understand from the phrase "utilizing cables and insulated conductors" in this context?
As I mentioned before, does "cables" mean composite cables such as T&E, and "insulated conductors" mean singles for conduit use, perhaps? That interpretation would mean that with T&E you can use 1.0 for lighting circuits, but need 1.5 for power circuits (however defined), but if wiring in singles in conduit you can use 1.0 for power circuits as well as lighting circuits. But that would make "cable" in note 5 mean any conductor in whatever form in its first use and only a composite cable in its second.
What other interpretations might we get from note 5?
