K
kai
From January 1st 2016, does the switch fuse need to be of an all-metal construction??
It is not yet 1/1/2016 and its is already installed. It can be made of anything that meets today's regulations, not the day-after-tomorrow's!From January 1st 2016, does the switch fuse need to be of an all-metal construction??
Yes.Also when you say switch fuse being the wrong way round? Are you saying the Split Con should be out of the top, and the feed in the bottom?
Yes but go easy on the switch, they are somewhat fragile. I would recommend calling an electrician to carry out this 'simple' task as it's easy to get it wrong which can result in loose connections and burning/fire at the terminals. All the terminals must be checked for tightness to any cables that are disturbed or repositioned in any way.I can isolate from the meter switch I guess.
