british gas rc plus
15 Nov 2011
Lancashire
i have a brisitsh gas rc plus (drayton digistat) and im having problems setting the date and time on the thermostat.
I have followed the instructions on the user guides etc by pressing the > to run through to 6 programs but once I have done that I cant access the clock to amend the date and time, the thermostat just reverts to the next option which is holiday mode. So basically every time I run through the options it skips the clock.
Is there any other way to reset the clock because at the moment I can not set the heating to come on automatically as the date and time are so far out?
Many thanks
Stephen
Did you ever work out how to fix this as I have exactly the same problem. Followed instructions in manual and it always skips past the clock icon!
Traven
I need an answer to this question asked by TMcL and cannot find one anywhere. Can anyone please help?
obviously not
try searching "drayton digistat"
The manual doesn't address the question. As has been said:
(1) "Once I have done that I cant access the clock to amend the date and time, the thermostat just reverts to the next option which is holiday mode. So basically every time I run through the options it skips the clock."
(2) "Followed instructions in manual and it always skips past the clock icon!"
Where can I find the answer to this question?
I'm aware that the question is old. But the point is that I'm trying to find an answer to it. It isn't helpful just telling me that I'm looking in the wrong place. Unless you can suggest where I *can* look, I'd rather not hear from you. :)
You cant access the clock, if its wrong it needs replacing. Strange but true.
So it has 6 timed events per day,,i enter a time for each event to begin,,but for how long does each event last,how do i stop each event?
