F22 fault
And what sensor clogging would that be then tony
I would imagine it one be one in the boiler what measures the water pressure inside the central heating loop.
Can I suggest you look at bunnie's van picture:)
Bunny rabbit is the logo that goes with Vaillant boilers
What bunnyman does not know about Vaillant boilers, is not worth knowing:cautious:
Steel, either you are on night shift with nothing to do or are sleepless:ROFLMAO:
Sick of going out to blocked sensors showing F22 fault seems all I do:rolleyes::ROFLMAO:
Hey guys, I tried turning it to on and nothing happening, this is what's in the loft!
Whys that steelmasons? Any idea what I can do? It just says safety switch off water shortage!
The silver valve that can be turned with a screwdriver is one below that is another valve that should have a handle on it but doesn't. You'll need some pliers or similar to open it.
Yep
Should have a black handle on it.
When that 20yr old cyl starts leaking and needs to be replaced get your installer to fit a filling loop in a sensible place
Got the pressure uo its says that 2.5 on the boiler but I stopped at 1.2 on the gauge, is it OK to turn on?
What gauge the one on the boiler doesn't have any numbers on.
Release a bit of pressure from a radiator bleed point or draincock into a jug or similar. 1.5 is what u want.
There was a gauge next to filling loop in the loft! It's still sitting on 2.4 - 2.5 I bled all the rads and took about quarter of a pint out one of them, should I just carry on taking water out?
