I'm trying to clear an air lock in our cold water feed to bath that I believe got there when i drained everything down to replace isolation valves.
I want to connect a flexi tap connector to the 22mm cold feed, and then connect the hose to this.
I have an outside tap connector so would need some kind if nipple to join the two, what size nipple would this be? Would it be a male>male of the same size, 3/4 bsp or is it 1/2"?
Thanks in advance!
Thanks in advance!
