dimmable Gu10 bulb with non dimmable switch
  • Thread starter Thread starter ih
  • Start date Start date
ih
4 Nov 2006
London
Hi
1.Is it OK to use ordinary non dimmable switch with dimmable Led Gu10 bulbs.
2.is it possible to get budget chrome dimmer switches with 0 minimum load(if not what min load can I get)
Max can b 250/400? if so pointer will be appreciated.
thanking in advance
Hi
My lighting circuit is 16amps kindly advise if I need 10amps switch or 20 amp ones.
thanking in advance
ih
Hi
sorry typo it should read 10amps
thanks
Be careful, your switches, bulb holders, etc... on the 10A circuit may only be rated up to 6 Amps.
But how much current is ever going to pass through a switch or lamp holder?
I'm sure there is a reasoning behind using a 10a breaker and not a 6 (hopefully it's not just 'that was all he had in the van')
  • Thanks
Reactions: ih
Although I'm no great fan of using a larger OPD than necessary (and that includes using a 3A fuse in a BS1363 plug when a 1A one would suffice!), if (as will usually be the case) one is confident that nothing on the circuit is capable of creating a sustained overload current >10A, if (as will hopefully be the case) the circuit has adequate fault protection and if (as will presumably be the case) the cable has a CCC of at least 10A, I'm not sure that there is really any problem (either electrically or regs-wise) in having a 10A OPD, is there?
  • Thanks
Reactions: ih
thanks very much for all very valuable advise & help will get the necessary checked.
