My loft conversion is finished and I've just had the final building control inspection.
A few days ago a different team of builders (not the loft guys) started doing some other work, which involves dividing the large through lounge into two smaller rooms, each with its own door. The partition wall is up and they've fitted fire doors and fire door frames in both rooms.
The door stops on these two doors look different to the ones in the other rooms - well the only difference I can see is they're narrower.
The stops come from the original fire door frame / lining pack, so they're presumably fire rated (wouldn't make sense otherwise). The stops don't have FD30 labels on them, but the lining sets do.
The inspector said these stops are not fire rated and has asked me to replace them with FD30 ones. At the time he said it I believed him, but after he left I checked with the builder and he said they came from the original fire door lining packs.
Now I'm wonderinbg what to tell the inspector to convince him? Is there a surefire (no pun intended) way to tell if a door stop is fire rated or not? Like a certain thickness? Or maybe a label somewhere inside?
