Hi all,
We posted last year because we were having damp problems in the ceiling of our self-built extension. We hired some builders to insulate, construct and plaster the ceiling as we were unable to do this ourselves. We subsequently found that the ceiling was under-insulated, had no vapour control layer, and had air gaps between the edges of the celotex with no filling. After a frost we would get patches of damp on the ceiling which with the help of the members of this forum we found were due to condensation. Unfortunately our architect was also a cowboy and did not provide adequate drawings with specifics of how the ceiling should be constructed.
We are about to rip the ceiling down and re-build it ourselves with the advice we have received from this forum, and we just want to check and clarify a few things before we start.
I have attached a diagram of the ceiling in its current construction, and also of what we intend to do when we rebuild it. We would really appreciate it if someone could have a look at these diagrams and answer the following questions for us.
Here are the diagrams of the current and intended structure (click thumbnail for full size version):
Thank you all very much in advance for any advice you can offer.
- Is each layer in the intended layout in the correct order?
- Is the second layer of batten (between the VCL and the 40mm celotex) necessary?
- Will 40mm celotex be sufficient or should we use thicker?
- With regard to the VCL:
- Is any particular type recommended (e.g. PVC, thin foil, foil bubble sheets etc)
- Is foil-backed plasterboard/celotex necessary if we are using a VCL?
- Is the VCL necessary if we use foil-backed celotex and use foil tape along the joins?
