I have a bathroom with, accent lighting (leds) and a main light that triggers the bathroom fan which stays on after the light is used.
the accent lighting is on a separate switch and basically controls two 12v power supplies for LEDS.
Id like to have one of the following two options:
Option 1: two gang switch one switch turns on the accent lighting, the other switch turns on the accent lighting and the main light which will trigger the extractor.
Option 2: Some kind of off on1 on2 wall switch or three position switch to accomplish option1, so the first push or position of the switch is accent lighting on, the second push or position is all on. third push or position is all off, however id like to be able to get from accent to off without having to go through all on. mainly to avoid triggering the extracts, for middle of the night visits to the bathroom, or relaxing quiet baths.
im guessing option1 wouldn't be recommended because the light switch could be off but the circuit could be live due to switch 2?
thanks
thanks
