Winston lives in the past, tubes are more advanced and most 8** prefixed lamps in manufacturers specs will be good for 2 years, I challenge Winston to find any starter specification that can match that.
Another thing worth considering, when you turn them on do you get an annoying flickering first.
For extra cost you could fit Electronic starters, these delay the on then come on first hit, the delay is no more than the annoying flicker, but looks more proffesional, google part numbers BG EFS 120 and BG EFS 600
So are you implying that in the past starters lasted longer? Maybe that is right as I have starters in use 10 to 20 years old that outlived several tubes.
Incidentally the electronic starters I have come across are only for bigger tubes not the miniature ones under discussion.
What I am saying is tubes last longer now than they used to.
Of course some people have had starters years as well as tubes for years, but unfortunately some starters fail after months and some like SBT brand even crumble into dust.
If you read any sales gumph prior to Hf ballasts.
Ge polylux one of the first 8** Triphosphor tubes, would guarentee there tubes for 2 years providing an electronic starter was used, hence lamping firms that done so, could relamp companies like mcdonalds and Abbey national, yearly and apart from fitting issues them lamps should still be lit and replaced prior to any failing, which was more economical than labour costs, for 1 lamp here and there.
They could not offer this warranty with any basic starter as there was so many starter brands both good and bad.
I have no doubt your right in some cases, but in a lot of domestic cases you will proberly find the original starter still fitted and that may have already lived through a few tubes or more likely a cheapo from poundland or woolworths, so IMO if your weighing out for a long life lamp, then stick a new starter in and hopefully your trouble free for some time.
So when the light fails what do you suggest, order a lamp and hope it works, then if it dont, waste more time and money running round for a £1 starter.
Or a week after you fit the lamp, the client calls you back because its flickering, what would you say oh sorry mate I charged you 30 odd quid to fit it but I tried to save you a quid by leaving the manky old starter in.
You may be right about the electronic, I forgot he also had two 8 watt, the EFS120 only goes as low as 15 watt, however the majority of the tubes the op has are T8 tubes 18w and 30w so hardly Miniature ones, whatever they are.
"Bigger tubes and miniature ones"
