- Joined
- 17 Feb 2016
- Messages
- 7
- Reaction score
- 0
- Country
Hi All,
I have a Worcester 28si Combi Boiler, my current thermostat is a T6306 and I am replacing it with an Evo Home.
When I isolated the power, removed the existing stat I found three wires connected; the wires were a perm live, switched live and a Neutral - the existing wires were located in the following terminals on the T6306:
Perm Live - 1
Switched Live - 3
Neutral - 2
I fit the BDR91 and setup the wiring as follows:
Perm live - first L terminal
Neutral - N terminal
Switched live - B terminal
and I then linked the second L terminal to the A terminal.
I fit the PCB cover, turned on the power to the boiler which was fine but the BDR91 had no lights active (no power) I tried holding down the button to get into sync mode with the Evo but again no power.
I thought maybe the BDR was dead so I went and purchased another but again in the same setup the boiler had power but the BDR didn't so I could call for heat.
Does anybody know what I can do?
P.s I set the boiler to always on and not on a timer.
Perm Live - 1
Switched Live - 3
Neutral - 2
