Bit of advice needed...
Living room - 3 way dimmer switch. A couple of the knobs were slipping off (too loose) and when you turned the knobs they were slipping and not actually dimming the light.
Size of dimmer unit: 150mm x 90mm (standard size I hope)
Operates:
wall lights | one set of ceiling spots (8) | another set of ceiling spots (7)
There is another light switch at the other end of the room (not a dimmer just a standard on/off - pic attached) that turns off one set of the spotlights (dining area). I hope this doesn't make things more complicated!!
Anyway, as the knobs are always slipping off I put a little super glue onto the inside of them and attached them back on the inside of the switches. Problem is when I pressed down some of the superglue went onto the shaft of the switch and now they're sticking and difficult to switch on and off (I know, I know)
They've always been a bit temperamental and not smooth and I want to replace them.
The spots are all 4w LED energy efficient ones and I think the dimmers might be 400w or something, so they can flicker when turned right down and dont dim as much as the old school halogen bulbs.
Question 1: Is it just purchase a standard like for like and replace?
Question 2: I tackle a fair bit of DIY but always leave electrics to a sparky. I've replaced a couple of simmer dimmer switches like for like but when I opened the cover it was a lot more complicated
Question 3: If I'm not comfortable with changing it due to the amount of wiring how much would a local qualified sparky charge for such a simple change? I would imagine its a 15 minute job, I just hope the fact that the switch up the other end of the room that turns off one set of the ceiling spots doesn't complicate it?
Lastly, it was a bit difficult to tell if the lights were actually on or off or just turned right down - if there's no buzzing from the unit and (OBVIOUSLY) the lights are off, then should all be safe when we go to bed?
Thanks in advance
Operates:
Thanks in advance
