I have some LED light fixtures that were bought from China. They are generally all metal with a plastic shroud to cover up the guts of the fitting. Inside they have an LED transformer.
I've wired a few up and they work perfectly, but the issue is that they have no attachment for the ground wire. With these types of fittings, there's no bulb to replace so no one should be touching it unless the thing breaks. I'd still like to make sure it's properly wired up though.
Some images below of the fitting:
Appreciate any suggestions on what to do - other light fixtures I've put in the house have been from IKEA and they had grounding screws attached to the body of the fitting already, but they were also traditional bulb based fittings.
