As a proof of concept, I serviced mine with one hand.
Which the Intergas isn't.
You set it up properly with a sensible flow temperature, just as all condensing boilers should be set up. Yes, if you go and set your flow temp to 80 then you're going to get some hotter water coming through initially, but you shouldn't be doing that anyway! There are ways to combat it if you are someone who insists that radiators should be hot enough to jump off the walls thoughIf they shared the same heat exchanger, what stopping hot water from over heating if heating is in used?
Daniel.
What were you doing with the other one?As a proof of concept, I serviced mine with one hand.![]()
There's always SWMBO's kitchen step ladder (she can't reach the wall cupboardsshort arz)
