I do agree, hence the inverted commas.
S'quite alright, I should have been clearerSorry.
Well than - that's simple.He can't engage in debate about it , it's either done his way , or not at all !
And have you been, or is that accusation just one more manifestation of his idiocy?I am accused of telling him how to do his job by looking up answers on mums net !!
Why are you?He also removed my 2 seperate 10mm2 earths , and replaced them with 1 16mm2 one! , then proceeded to rewire both the neutral bars so that the numbers matched the breakers !! , (they weren't mixed between rcd and non rcd of course) , so I am going to pay him to do all this unneccisary stuff !!
If that's so, then I have no idea when it started to become accepted as being recommended "good practice." So long as there is nothing about the design of the breaker terminal which makes it suitable for only a single conductor, then there is absolutely no reason not to run two branches of the same circuit from one terminal (obviously in the case of a ring final there have to be two conductors there!).I realise after questioning a few, that all sparks are taught this, but none of them know why, other than "good practice"!!!, but the cleverer ones realise that its not something thats in the regs, just the recommended way
Though in the U.S. now, I'm actually British, but as my background is more electronics & telecommunications, not whatever might be termed the "normal" British electrician's training, I was immune anyway!thanks PBC, you are in the US!! hence immune form this indoctrination that UK sparks are infected with!!!,
Then for pity's sake stop quibbling and let him do it the way he wants - you have absolutely no right, in these circumstances, to do anything else.Yes, I do understand that he is doing us a favour by signing off our work,
If all he is doing is the inspection and testing part of a 3-signatory EIC then be aware that BC might well, at the end of the day, ask for design and construction signatures.but i believe the BS form he is completing is , I believe, a test?, and doesn't have any boxes asking who did the work??
When you applied for Building Regulations approval, before starting the extension etc, what did you say, or allow to be said on your behalf, or what assumption did you by default accept, would be the way you would ensure compliance with Part P?No one asked me who's going to be doing the work when i started
I'm not surprised. You really don't know, or want to accept, how all of this works, do you.Interestingly , I also installed a wood burning stove and thermal store, complete with new twin wall chimney , I couldnt find a HEATAS engineer to sign it off, for love nor money!!
They will do neither.I certainly know the BCO won't be poking around in the CU asking why there are 2 wires in the ground floor lighting breaker!!!, he's more likely to ask why there are 2 breakers for the ground floor lighting (if we do what my sparks wants)
