It's not a fault with the boiler. It a fault with the system design / implementation.
ok, apologies if offence given, I will put it differently. I decided I wanted evohome+a new boiler, I found 3 local installers on the honeywell site who were evo certified, talked to all of them, went with the one I felt happiest with. they specced the viessman, and the OT. I still have an amicable relationship with them but I would like to steer them in the right direction to resolve it, rather not have to call someone else in (implication being I'd be trying to recover cost of that from the first guys). if we can fix it with relatively small changes (i.e. not a new cylinder or boiler) then it stays amicable.There are specialists, and there are "Specialists". I think it safe to say that Simon and I are the later.I did seek advice, from my installer, an evohome specialist.
I think we have given you the answers you need already. To be Frank though, as Simon implied, if the installers came up with the spec, they should be solving the issue.
What's the point of getting the manufacturer out under warranty? It is a controls issue, they will test the boiler as if the controls are not there just to prove the point. They will know somewhere between diddly squat and sweet fa about Evohome, although they may well repeat the advice already given here.
Get the hot water doodahh for the boiler (well, IIRC it came with the boiler but the installers threw it away). Then connect the system as per the drawings in the Honeywell books.
make it y-plan
make it y-plan
Did he actually say y-plan?
yep, makes perfect sense. I think my installers expected OT information from the evo controller to enable to boiler do that adjustment automagically, but its clearly not working. So, ditching the evo OT for a BDR91 and wiring the hot water kit's output into the cylinder demand terminals on the boiler is the next best bet, am I correct?The boiler can only output one temperature. At a time, but it needs to know the difference between Heating and hot water to adjust its control logic.
I know its not a y-plan as strictly defined based on where and what type of valves, how they are controlled, etc. But it gives a logical OR, i.e CH OR DHW, which is exactly what Y-plan does, therefore to me, that proposal was pretty much analogous to running the system as Y-plan.That isnnae a Y plan.![]()
PL= Permanent live.
In other words, try removing all OT stuff and running the boiler into the Pandora only, with the zone valve wedged open.
We've fitted a number of Pandoras (whilst DPS were extant) and it is a great product. It is just a cylinder as far as the boiler is concerned.
WB1B is a pain sometimes because the Viessmann logic does try to modulate the burner too much IMHO.
Adding OT to one was a crazy idea; many of us in the trade understand the benefits of OT on paper, but like Dan says, the reality is often not quite as compelling.
There are people on here encouraging others to use OT, but they are in the main not heating installers and have no experience, just opinions and Google.
