Black Mould On Grout
16 Feb 2015
Kent
Can anyone suggest the best way of removing black mould from tile grouting in a bathroom.
I've been using bleach which gets rid of most of it but 2-3 weeks later it starts to
appear again.
The grouting is about 4 years old.
Mould is caused by inadequate ventilation which results in surfaces being left damp/wet.
Either improve the ventilation, or expect to clean the mould away all the time.
Thanks for you reply.
Inadequate ventilation was the original cause. This has now been
rectified.
The mould always appears in the same places,so I'm guessing that the diluted bleach
I'm using is not killing the mould spores.
Are there any other products that could be recommended ?
rectified.
I know I'm flogging a dead horse but your first mistake was using bleach on the grout. That can cause some horrible discolouration and will damage the grout joints and tile surfaces.
What should you use as I have the same problem. Aldi grout cleaner removed the mould but it's now back as bad as ever. I note that was bleach based.
I would use BAL Micromax Spray (not sure if this was just in topps) or FILA Grout cleaner. I buy the grout cleaner and sealer whenever I move house and inevitably lose my old stuff. Sealer means that I thw dirt doesn't get mashed into my kitchen tiles.
