Hi all,
I have a Worcester 28CDi RSF with a leaking hot water service connector from what I assume is a worn out o-ring. I can get to the connector easily and the connector does spin round the joint if turned with a wrench once I loosen the outgoing compression nut.
My question is there a correct procedure to remove this? My instinct is to use gripping jaw pliers and wiggle it out but obviously don't want to have to force it.
Thanks in advance.
Thanks in advance.
