imo not fit for purpose , what a total waste of time and money down the drain, can't even take into consideration simple controls now what is the point of that, total joke
All of the stats do have time control, they are all linked to a single programmer that controls the entire system, exactly as a system with TRV's would be.He seems to be suggesting that if you insist on having him come back that you may end up with a poorer rating. Due (as he suggests) to not having time control over each of your stats.
No, unfortunately not, the heating came with the bungalow when it was new in 1981. The motorised valves (one of which is still an original!) were added about 2 years later by my father who was a registered plumber, (he didn't do the wiring) but he died 25 years ago. Since then, my mother has had it serviced annually by BG under a service scheme which is documented, they also changed the 'heat only' boiler for a 'combi' 10 years ago, but didn't change the control set up.Does they guy that installed this setup for you still service the boiler there? No doubt someone will ask for service record.
It's also why the EPC has suggestions for things which make no sense to anyone - such as paying £4000 to install hot water solar panels
Dig the whole thing up at a gigantic cost with massive disruption then insulate, replace concrete, redecorate every room and all to save next to nothing.It also mentions insulating the solid concrete floor, which I guess sounds reasonable, but does anyone actually do this? and if so, how would it be done?
Makes you wonder how they cope with huge places worth 20 - zones of mixed emitters and energy sources.
I responded to the company that sent the assessor, and sent along some photographs showing room thermostats that the assessor had 'missed' and the reply was:
"If your are happy for me to resubmit without a revisit if I changed the controls to programmer and 2 room stats but would need a revisit for me to record the heating controls as time and temperature zone control"
I have cloned the EPC to assess the impact of both of the above options and the outcomes would be as follows
Existing EPC - EER 63, EIR 63
Programmer and at least 2 room stats - EER 64, EIR 65 (recommendation for TRVs would remain)
Time and Temperature zone control - EER 66, EIR 67 (recommendation for TRVs would no longer appear)
Can you please let me know which option you want me to proceed with. As I said before I am happy to revisit the property"
As the change is insignificant and wouldn't appear to have any effect to potential new owners anyway, I have instructed them to leave it. Also, I wouldn't really want the same assessor again as I have doubts about his competence. I've told him several times there are 5 thermostats, one for each room, and even sent photographs, but he keeps gong on about "2 room stats" and his command of English seems poor too..... or is it me?........![]()
