Been a long time since I was at school and learning about the interaction and relationship between electrical and magnetic fields and the angles of the fields that pass each other. (90° IIRC).
Just wondered whether one would hypothetically be able to obtain a small amount of unmeterd and illegal energy by wrapping a coil of wire (acting as the secondary side of a transformer) around the incoming meter tails before the meter.
Would this behave like a inefficient transformer should current be going through the meter tails or would this simply not work.
And how much use would this be should it work. i.e. Could you power a door bell of it for example?
Regards: Elliott
Regards: Elliott
