Sorry, I have a glowworm 30cx fitted 2 years ago serviced annually. I have central heating but no water from the hot tap, either hot or cold. No warning lights, I figure an automatic valve has shut off. I tried resetting it. Pressure is 1.4 bar.
your hot and cold pressure on boiler gauge has nothing to do with hot and cold ,its showing pressure on your system water ( heating ) . is all taps the same ? is your stop tap turned on or service valve under boiler ?
what automatic valve has shut off ??? is your heating working ?? have you recently had any work done in your home ?
one of the valves used to top up the pressure via the filling link underneath the boiler has been left open that is why you are not getting any water out of the tap
That is exactly what it was, thank you Ian the handle turned around the valve instead of turning it off. Thanks to everyone who offered suggestions. Much appreciated but Ian gets the biscuit.
