Love me new van but need to sort out the electrics.
It had a load of electrical extras, some of which were removed pre sale by the fleet owner.
Inverter; beacons; rear work lights; water heater and cab heater were all cut off and removed.
The loom is all still there, but with 'open' ends. There are labelled switches on the dash, an isolator for the inverter, fuse holder from the batteries to isolator, double plug socket outlet with RCD protection mounted to the bulkhead, 'blue sky' auxhillary fuse board in the cargo bay, reversing camera and LCD, fluorescent lights in the cab and cargo bay - these remain.
Over time, I may reinstate some of the above but for now, my main aim is to get the interior fluorescent lights working in the cargo bay and cab, as there is a fault which I suspect is to do with unterminated 'ends' from the removed components!
I've carried out some testing with my self priming digital multimeter but vehicle electrics is not one of my best skills and I have limited knowledge!
When I attempt to operate the lights, using the dash master switch I get one tube in each of the 3 cargo fittings coming on very dimly AND the reversing alarm/beeper sounds. Rocking the switch again, stops the alarm but kills the lights completely, further operating the switch repeats this pattern!
I removed the tubes from the fittings, checked the fuses in the auxhillary fuse box and am trying testing with my meter... ONE probe of the meter on the positive pins of the fittings gives a fluctuating reading of 28-45v DC! but that's just one probe, I'm not measuring across the pins! The other side (earth ?) gives no reading.
Can anyone guide me where to go next as I am a tad confused
