Should the gate screw off the stem completely? No sign of broken parts.
Yes, but what you don't know is if the thread is actually correctly firmly locating in the female part, it could be stripped.
But I still don't think you have any water on the pipework side of the valve.
But you don't want to unscrew the nut to check as we have asked you to do.
Tony
You drained it in drips you said.
It should be coming out at up to 12 li/min.
When you drained it out is the header tank empty?
The male thread "pulls" or "pushes" on the gate as it is turned.
Tony
Oh dear!
Don't you realise that by blocking the outlet you have deprived yourself of the most important test of whether the outlet pipe is not blocked.
Always turn off water to ball valve or tie it up.
Then see if water drains promptly out of the header tank. It should flow out at about 10 li/min!
Tony
the reason i didn't want to do that was because i couldn't deal with that amount of water!
