Wondering if anyone can help diagnose the fault I'm seeing with my cold water feed upstairs, where we've got very low flow from the cold water taps. The flow from the hot water taps is fine, and is much higher than the cold water.
The cold water is mains fed and is T'd after a pressure reducing valve which feeds the unvented hot water cylinder. The pressure is set to 2.1 bar.
Upstairs there is a shower, toilet and sink all of which are suffering from low flow, particularly the shower, which cuts of the heating due to low flow. I've checked the strainer of the shower and it is not blocked, but the problem is common to all the fittings upstairs.
There is a stopcock on the run up, but I've replaced that with no improvement.
The only things I can think that might be causing the problem is a blockage in the line somewhere or possibly an airlock. Any suggestions? I don't think it's likely to be an issue with the pressure reducing valve as the pressure from the hot water cylinder is fine.
Any suggestions gratefully received!
I've attached a picture showing the lineup after the pressure reducing valve in the hope it helps.
