I've fitted a few of these as I've progressively replaced radiators in my house. So far I've used PTFE tape into the radiator and then PTFE from the valve into the extension. Although the valve tail is a taper thread, the one on the radiator end of the extention appears parallel, and I've had problems getting enough tape on there to make a decent seal. It's got me thnking...should these come with an o-ring instead, like a modern bleed valve does?
