14.8 roof pitch
9 Aug 2016
hello, I'm achieving 14.8 degree pitch, am I worrying over nothing as it's almost 15 degrees or should I do what I can (substantial work required) to achieve 15 degrees?
I'm hoping for a slate looking finish, Cambrian or Eternit thrutone fibre cement slate also with velux
What are you using to measure an angle to tenths of a degree?
Normal tolerance is to within 1°
Sorry to be vague but I don't know. My neighbour and I are both building a single storey extension, he's got someone else in and slightly ahead of me, I'm not at that stage yet, ideally I want us to lay the roof as one, that's the pitch his builder advised. maybe he meant just under 15 degrees.
last time I had to do it , it was in minutes and seconds and a book of logs:notworthy:
Hey, don't knock the squinted eye, thumb and stick method. :mad: That was used long before you whippersnappers and your log tables and fancy trigonometry came along.
For the OP though, don't worry about one fifth of a degree - your angle finder is not that accurate anyway. And a degree either way won't make much difference
The deflection in the rafters would be more significant than 1/5th of a degree.
I had an issue with a roof that had cambrians specced years ago and Redland technical said they would probably be ok as low as 12 degrees anyway
Don't use Cambrians. I have had nothing but problems with my roof at 15 degrees. I would use a tile that has a few degrees extra to give you a bit of guarantee they might actually keep the rain out.
