Fair enough - so do I take it that your "Yes" answer actually means "No"?Yes, your post wasn't there when I posted a response to EFLI at #22.JohnW2 said:Does that somehow relate to my immediately preceding post, or whT? ....
Yes (qualitatively, if not also quantitatively). However, as I said, you could not really use the argument that it was appropriate to use the same word because bottom-line functionality had remained essentially the same (merely 'achieved in a different way) - since, in the pre-SMPSU days, something which converted AC into DC was never called "a transformer".Has the voltage not been transformed?
No - although, in practice, the word "transformer" is only used for a very small number of things which transform. Transformers who are people, or groups of people, are a totally different issue.It boils down to this, according to you and Winston: Rule 1. Only certain things may be transformed by transformers.
No. Well, I can't speak for winston, but I have said nothing about "transforming"Rule 2. Only certain types of transforming may be called transforming
As above - although there are countless 'transformations', by convention/normal usage, the word "transformer" is used only in relation to a very small number of them.Rule 3. Other things may be transformed but this is NOT done by transformers even though the device transforming it has done the transforming.
That's a good point but it is not I who am limiting the use of these words; perhaps you should ask yourself or Winston.Given scientific and technological advances during the period of the Industrial Revolution, vast numbers of new (technological and scientific) things had to be given names during the 18th and 19th centuries - and I think that a substantial proportion of those 'new names' represented (partial or complete) 'hijackings' of words that had previously had other meanings. You surely don't think that they were all 'wrong', do you?
There are fuseboxes that aren't fuseboxes because they use MCBs instead of fuses...That's a good point but it is not I who am limiting the use of these words; perhaps you should ask yourself or Winston.
For example, are there, today, any rectifiers (or anything else) which are NOT rectifiers (or anything else) because they use different methods and materials than did the original ones?
I thought you were the one who was often critical about words being used 'incorrectly' (i.e. with a different meaning from what they originally had? Indeed, in this very discussion you have suggested that it was 'incorrect', all thsoe decades ago, for the wire-wound components we've been discussing to be called "transformers"That's a good point but it is not I who am limiting the use of these words; perhaps you should ask yourself or Winston.
I don't think there can be (in the case of "rectifiers") since it is a generic term defined in terms of functionality - whether one is talking about a thermionic diode, a germanium or silicon diode, a metal stack rectifier etc.For example, are there, today, any rectifiers (or anything else) which are NOT rectifiers (or anything else) because they use different methods and materials than did the original ones?
Just like the IEC definition of "transformer" then.a generic term defined in terms of functionality
Yes, linguistically.I thought you were the one who was often critical about words being used 'incorrectly' (i.e. with a different meaning from what they originally had? Indeed, in this very discussion you have suggested that it was 'incorrect', all thsoe decades ago, for the wire-wound components we've been discussing to be called "transformers"
Wriggling ??? They can't all have been first.I don't think there can be (in the case of "rectifiers") since it is a generic term defined in terms of functionality - whether one is talking about a thermionic diode, a germanium or silicon diode, a metal stack rectifier etc.
What did that mean?No. Well, I can't speak for winston, but I have said nothing about "transforming"
Indeed, in the sense that it is a purely functional definition, with minimal reference to mechanism (really only 'no moving parts'). To remind people, the definition you quoted was:Just like the IEC definition of "transformer" then.
I have to wonder whether they really thought that one through (in relation to what they actually intended). As written, it would seem to include a box with a resistor or three in it, yet would exclude a 1:1 isolating transformer. In the context of this thread, it would also exclude most SMPSUs because of the extensively-discussed frequency change (from 50Hz to "kHz" or zero).IEC said:"electric energy converter without moving parts that changes voltages and currents associated with electric energy without change of frequency"
In terms of dictionaries, that's clearly correct. However, as I have said several times, normal ('common') usage does not refer to many things which transform as transformers. An almost endless list of things - from an electric kettle, through my car or table lamp to a plant or my liver - undoubtedly 'transform', but virtually none of them are usually called "transformers".My point is that ANYTHING which transform is a transformer.
'First' is irrelevant to what you asked. As I said, the (I assume 'original') definition of 'rectifier' (at least in ordinary dictionaries - I don't know about the IEC!) is purely functional, regardless of the physical form or mechanism of function - so it does not matter what order they came in, since they all satisfy that definition.Wriggling ??? They can't all have been first.
I wouldn't call it 'confusing' but, as I've just written, although the dictionaries would allow what you are suggesting, in practice the fact is the vast majority of things 'which transform' are never called "transformers".Winston accused me of confusing 'transformer' and 'transforming'.
Probably. You can search at http://www.electropedia.org/Do the IEC definitions offer any suggestion as to what we should call a 1:1 wire-wound "device"?
