- Joined
- 27 Aug 2016
- Messages
- 18
- Reaction score
- 0
- Country
Hi there, moving into abother house asap that needs renovating and will be installing a wood burner in the kitchen/ diner ( since they'll be a sofa in the room and I'll spend most of my time in there). Number of reasons for this
1) I like woodburners, friends have them and it's just a nice thing to have in the room
2) I have a fairly large supply of free wood, so can potentially save some money on bills.
3) I'm a man, therefore I like fire!!
Originally was going to bung a 5/6kw stove in the room, job done. But have recently been thinking about having a wet stove... current plan is looking like this:
8-9kw stove.
1 gravity fed towel radiator in the upstairs bathroom
1 central hearing pump controlled by 2 pipe stats, powering 2/3 rads ( 1 In the living room, 1 in main bedroom and possibly one in second bedrooom)
House currently has a semi modern fully working GCH system and would rather not go through the upheaval/ cost of integrating the system unless theres a major reason too.
Anyone see any issues with my idea/ plan?? Is already cold mains in the loft, so would need a small metal header tank in there.
Reason I'm thinking of doing it this way is obviously the rest of the house ( save the hall/ landing/ study/ downstairs wc, box room- none of which we would spend much time in ) is getting heat from a free source. The other rooms would require running of extra pipework/more rads( with some of these rooms not really having space for 2 rads) and obviously a bigger stove and more wood to heat rooms we don't need to heat.
Having found a stove or 2 I like in the 1200-1400 range, £400 on flues etc, any reason why I couldn't have this done for sub £3k??
Also regarding building control if I chose to use HETAS registered engineer for the stove could I use a regular plumber to plumb in abd sign off the additional rads rather than doing it all myself?
Advice/ criticism/ being told it's a disaster is all more than welcomed.
8-9kw stove.
