- Joined
- 22 Sep 2016
- Messages
- 3
- Reaction score
- 0
- Country
Hi all,
I've taken much advice from this forum, first time poster, as I can't seem to find a post with a similar issue that I have now.
I am doing some research and planning into a ground floor extension. The semi-detached house has been extended in the past by roughly 1.6m (full width ~6m), but I wish to extend by a further 3.4m to make it 5m in total (therefore 5x6m).
Ideally, I will be able to leave the existing extension intact, have the new brickwork laid, then re-roof the new 5x6 structure. This is so that I can keep the kitchen in use whilst the project is ongoing as I plan to do most of the work myself to keep costs down.
The existing extension has a solid double skin wall with no cavity (215mm). I understand that to conform with building regs, I require 50-60mm Kingspan and 10mm gap within the cavity of the new walls.
My issue arises when planning the roof structure for the whole of the new extension, specifically the top plate which sits on the internal skin.
Regards
- If the internal skins are built in line with each other, the top plate is not an issue, but the new outer skin will protrude on the external. Does this make the roof design complicated to terminate at two different points, or can the new external skin be approx. 1 course of brick lower than the original extension?
- If the external skins are built inline with each other, the top plate cannot run in one length. Can an internal structure be built to support the top plate within the original extension?
Regards
