The property we are renovating has a 3 phase-fed, off peak, ducted, warm air heating system - and it works surprisingly well. It has a single phase immersion on the off peak as well and a normal tariff daytime top up.
That's the easy bit.
The house is a being extended and completely rewired. (largish three bedroom dormer, large garage/loft, workshop, outbuildings, etc.
I'm also going to install my old 3 phase machine tools in a new workshop.
The original domestic (6 way) consumer unit was an ancient Wylex with wire fuses and fed from one phase.
The electrician has done most of the new domestic wiring and replaced the consumer unit with an 13 way split load unit - but still fed by one phase.
The supply for the heater and immersion is still on an ancient MEM ceramic/wire isolator - from all 3 phases - no RCBO/RCCD protection whatsoever and is about to be replaced. He has produced - and I've paid for - a large (expensive) Schneider Acti9 Isobar distribution cabinet, with 12 three phase outgoing ways - as in 36 terminals.
Trouble is………. he's baled out of it.
My questions are:
would it be better with the 'domestic' side of it split between the phases (at least two of them)
where is the best place to protect this lot?
how is the wiring for my new workshop and 3 phase machinery best laid out?
Doubtless there will be other questions as well.
I want to understand what any future electrician should be doing. Rewiring the rewiring is not what I'd consider a useful way of disposing of my limited funds.
Given time and research, I'm confident I could do it - but it will still need to be signed off.
Pat'sPatter
ps I'd put a photo up if you're all certain no one will have nightmares…………….
My questions are:
Pat'sPatter
