As the original poster I just wanted to say thanks for all the info. To be honest, the subject matter has now turned to things way over my head. A few years ago we wanted to change our warm air heating but ended up keeping it due to the difference in opinions across the various companies/engineers we asked to quote. We find our ourselves in the same position now. We have spoken to 3 companies all of which tell us different things. One favours the combi, one tells us the combi is no good and we need the unvented cylinder and the other suggests we go with the old fashioned arrangement with tanks in the loft. We asked all 3 to provide quotes for combi and unvented cylinder options. As far as combos go, each has recommended a different size boiler with different reasons. None of them have checked our incoming water supply apart from turning on the tap and saying that it will be fine. I appreciate that the combi/cylinder decision is down to us but I struggle with the boiler sizing and operation. I showed all three the water coming out the hot tap and asked how this would compare; it should be similar but cannot guarantee it - well surely different size boilers will produce different results? Showed all 3 the pressure from the shower, one said the pressure would be about the same, one said they could not be sure (and that was the largest boiler!) and one said much better. I need to research this further but expect we will just keep the warm air again. Thanks again for the all the info.
