Hi, can anyone tell from this photo what materials have been used on my internal party wall? It's at the base of the wall where it meets the floor.
I've posted about damp on it and have been told by a damp specialist that the grey is carlite plaster which has been wicking up moisture and I need to hack it off, get a chemical DPC plus waterproof sand/cement render. However I have pulled a chunk out and wonder what the yellowish material is above/behind it (which he didn't see - he said the whole wall was carlite)
Is it just a plaster base coat or could it be a sand and cement render and might it have previously been applied to the walls to hold back damp? The carlite plaster only seems to run to the height of the lowest brick so might it just be there for the old skirting to attach to?
I can't knock picture hooks in up above holes have to be drilled so surely that wouldn't be the case if it was all carlite?
I've had the house 24 years and had the walls skimmed 10-12 years ago. The damp is manifesting itself as a dark patch - no salts, no yellow stains so I'm wondering if it's coming through the carlite up the face of the plaster skim without touching the assumed sand/cement render below? Might it explain why there's no damp on the other side in my neighbours house?
If so, could I avoid the need to have it all hacked off if the origins of the damp was resolved (currently assumed to be damp in the hearth/chimney breast and it was allowed to dry out? Thanks.
