- Joined
- 9 Oct 2016
- Messages
- 13
- Reaction score
- 0
- Country
I fitted some new waterfall taps to our upstairs bathroom this week, All went great, except the hot water pressure, which was never great, is now awful through the modern taps compared to the 30 year old ones I replaced.
Currently I have a hot water tank in the airing cupboard 1st floor and a feed cold water tank in the loft, so approx 2m head to the highest outlet.
22mm pipe outlet to 15mm feed pipes.
We only ever have been able to run a single outlet of hot at any time, including downstairs bathroom shower and basin.
So I decided to try this pump from screwfix, 2 bar single pump. Having done a fair bit of reading I am sure this is a positive head, so thought this pump would easily sort out a single outlet. http://www.screwfix.com/p/stuart-turner-showermate-eco-s-positive-head-shower-pump-2-0bar/58748
Very carefully fitted it but cutting the 22mm outlet pipe before it hit ANY of the supply pipe, put a 22mm to 15mm reducer in and placed the pump on the floor next to the hotwater tank, and turned all the water and tested outlets. Water flow was as before and couldn't see any problems even with placing the 15mm and a couple of bends to the new pump.
Then wired it up, putting the inlet to the connector next to the connector marked as inlet. Turned on a tap hoping for a huge flow improvement, and..... the pump started almost immediately made lots of pumping sounds and no flow improvement. Turned the tap off and the pump carried on running.
So took it all apart and this time primed the pump without connecting the outlet connector. Exactly the same result, even testing with downstairs outlets, there may be better flow to the downstairs bathroom but really not sure. But anyway the pump isn't turning off, turns on fine but hasn't turned off once, I have to use the electrical isolation switch.
I tested flow, to fill a 2 litre jug takes exactly 23 seconds in the upstairs bathroom both with and without the pump running.
So I know this isn't a whole house pump, but surely it should have worked for any of the single outlets?
Any pointers to what I've done wrong or have I just got a faulty pump? (float switch in the outlet is moving up and down freely)
I have now ordered this pump to fit tomorrow, but would like to know what I have done wrong, if anything?
