Quick question for you Building Regs experts.
I've got a bit of a tricky one and I've run out of steam arguing with the building inspector. Its a split level house so single storey at front but ground slopes away to rear so it includes a lower ground floor to rear making it 2 storeys. I'm working on a loft conversion and run into problems with the building inspector over the protected staircase. He wants a fire door at the bottom of the stairs on the lower ground floor level but I would rather keep the lower ground floor open plan.
My argument is the final exit is on the ground floor so in the event of a fire people in the bedrooms in the loft will only have to come down one flight of stairs and out the front door. Together with linked mains smoke detectors on all levels and fire egress windows and fire doors on the ground and first floor rooms the proposed layout is no more risky than a standard 2 storey house except to the rear the new first floor is more than 4.5m above the lowest ground level.
I've gone through the relevant determinations and cannot find the exact same circumstances but some similar such as a 3 storey house with an escape route on the first floor which have been allowed. I don't really want to go down the determination route so wondered if anyone here had any pearls of wisdom I could try to convince the pedantic building inspector.
Yes it is local council inspector and yes I know I should be using a private inspector. I wont be making that mistake again.
Thanks.
Thanks.
