- Joined
- 21 Sep 2011
- Messages
- 4,840
- Reaction score
- 1,169
- Country
I am fixing a heavy canopy at home, the bricks are brittle and cracked with rawplug type fixings, so I went to chemical ones, but when drilling, the bricks tend to pop into the cavity as soon as the hole gets much deeper than 80mm or so no matter how carefully I drill.
The studs I intended to use are cut at 95mm so the answer seems to be the nylon sleeves for hollow fixings which will stop resin bleeding into the cavity, but there don't seem to be any 100mm+ sleeves around most seem to be 85mm or so.
The studs are m12 and as far as I can see the sleeves for this size seem to be 20mm across.
Is that the right size for m12 studs and why don't they seem to make deeper ones?
I did try pushing a piece of large wall plug through to try and seal the inner leaf but as the brick has burst on the inside the exit hole is oversized.
It has not been a good day, the drinks cupboard is looking more and more inviting sob, sob!
