What's this drill bit for??
20 Nov 2003
Left behind at my place by a tradesman many moons back. Can anyone tell me what its use is?
Basically a drill bit housed within a retractable cover. Countersink?
FullSizeRender.jpg IMG_2074.JPG [ATT]108403[/ATTACH]
i dont know but assume countersink by the shape off the outer sleeve
and rather than pilot a shank hole as its to large for a pilot as it would remove all material
It's a self centering pilot bit for drilling exactly in the middle of a hinge hole.
Gaz :)
Gaz :)
ahh that makes sense so the sleeve doesnt turn then ??
it just locates in the hinge countersink ??
It is a pilot, just a very large one, maybe for a number 12 screw, which is probably why the tradesman never came back to retrieve it, probably never uses it and never realised he had lost it!
Coolhurst, can you see a number engraved on it anywhere?
Gaz :)
Correct, it's free to rotate, ie, doesn't rotate in use! They get really, REALLY hot!!!
Gaz :)
Gaz :)
most door and window furniture tend to be no7s :cool:
We call them Vix bits. They only get hot in use if you don't clear them out (of swarf) and don't lubricate them (oh, and if and they are cheap Chinese copies). The Trend Snappy versions are a million miles better than cheap and nasty Chinese copies illustrated. And, B-A, most modern fire door hardware requires 4.5 or 5mm screws, not #7s!
i bow to you up to date active knowlage :D as always
most people dont even realize no7 screws exist never mind most older furniture use it (y)
You ought to see the size of screws that came with some 6in bronze bank Parliament hinges we removed last year. I reckon the screws must have been #14 or #16 and about 4in long. Bit big for a Vix bit, however
Thanks all. That adds up as we had doors fitted a few months ago so I now know who's bit it is!
Gaz - to answer your Q, it's states #12 on the side.
