I have two Domus H1 extractor fans which need to be replaced. I have purchased two Manrose humidistat fans.
The fans appear to be on the mains circuit, rather than the lighting, and they are currently wired to permanent live/neutral only. The replacements don't work when wired up the same, and it seems that they need a switched live too to function (the switched live on the originals was unused). If I want the fans humidity controlled only, could I run a wire between the permanent and switched live terminals?
