- Joined
- 17 Oct 2005
- Messages
- 222
- Reaction score
- 3
- Country
Hello - I have this 4" Extractor Fan with a Timer and Humidistat circuit board in it - there are 2 adjuster screws (pots) and one is for timer, one controls humidistat. For using timer you need 3 wires, 1 neutral, and 2 Lives (1 switched live, 1 permanant live) - the wires I have coming into the fan from the ceiling light are just 2 wires (live & Neutral) but for Humidity control I am thinking that it should only work with 1 live (ie, you only need 2 lives, one switched and one permanent live if you want to use it as a timed extraction)
so, its wired with 1live(switched) and neutral. Now, the Humidity screw according on the box should be turned fully clockwise so I have done that, the Timer screw, if I turn the timer switch all the way anticlockwise (even though it isnt wired up for timer operation) the fan stays on permanently, if I turn that timer screw clockwise the fan doesnt come on at all even when there is humidity, same if I put the timer switch to the middle. - so in other words the fan is either on permanently or off permanently and wont come on even when moisture is about - had two of these fans and they are both acting in the same way (just to rule out if the fan/circuit board is faulty) if I put a link wire from the live terminal, and the switched live terminal the fan is on permantly, it doesn't even go off even after something like 20mins.
I wonder what is going on here? - should be able to just use the fan in Humidity mode with just the live and neutral from the ceiling light shouldnt I? or the Live & Neutral or a link from the live to the permanent live connector of the fan shouldnt I?
Here's a pic on the box of the wiring diagram:
