Removing a small fluorescent tube from kitchen unit above worktop
At 20 years you've had your money's worth!
You have two options:
As SS says, buy a whole new LED fitting. = less hassle and another 20 years of happy lighting.
or
Struggle for a couple of weekends, missing the rugby, trying to get the one you have got working, only to eventually discover that the guts of the thing are cream crackered in any case.
Thanks it's really why the new one is flickering. It's been doing it for quite a while now so I don't think that will change.
jameseb
The 6 watt fittings around 20 years ago, had a starter in the side or front of the fitting usually near one end.
occasionally they had an electronic starter Inside the fitting, that tended to be accesible easiest by removing the fitting.
If its the most common type, the wires are plugged in to the ends of the fitting, you generally unplug the lead or leads,sometimes fittings are butted together, if so then you have to start removal from one end, then remove the 2 screws holding the fitting to the cabinet relamp and fit starter, then refit usually simpler than fumbling under the pelmet.
If the fitting end looks like shown below, then there is no starter is all electronic and not repairable
Thanks and that's great.
It doesn't have a starter.
I'll just have to get another tube.
JamesEB
I have just tried the tube in another fitting and it is the tube that is faulty.
Thanks for help
JamesEB
I have put the new tube in twice and now I cannot put the second new tube in.
Would someone please tell me how.
Sorry
JamesEB
I left this but now need to use it. I was told by the supplier at the time that is just a common fitting and anyone with DIY should be able to tell me how to put the tube back in.
Can someone help me please.
