Texecom premier elite 48w won't set
4 Dec 2016
so I installed my texecom 48w into my house a few months ago preogrammed it in and everything has worked perfectly so far. Until today I set up the com ip to get access via my phone etc. After setting up the IP address and setting up the app I went to set the alarm.
When I got to set it just gives a beep and the service light flashes orange.. then when you go into zone status zones 1 through to 9 are in tamper. But these zones are programmed as not in use
It's not coming up with any faults either
So I'm thinking it is something to do with the com ip
Please help!
The zones will still show tamper even if nothing connected when viewed through Zone Status.
What messages show when setting the system?
How have you programmed the alarm ?
Via keypad or wintex ?
Double check to make sure zones are programmed as not used
Go into engineer mode and then come out
Sometime service engineer comes on and just going in and out or engineering will clear message ?
The zones will still show tamper even if nohing connected when viewed through Zone Status.
It's doesn't show any message just beeps and won't set
Just worked it out what happens when you set up your phone it acknowledges and an external input device so you have to go into engineer mode and confirm it as a device
Cheers guys you twigged something in my head what I forgot about Should have done this at 8 at night
1. if you can set the panel using the keypad the app is no different.
2. the panel doesn't need anything inputting unless you generate an encryption key, and that only affects the app not the panels keypad.
3. to use the smart key app you need to correctly configure the user areas in the app not the panel.
4. you can get the app to remote set instantly the panel and for that you would need to change the system config option to instant remote set, otherwise as i said in 1 it behaves the same as using the keypad.
be nice if the poster could update with what they forgot as I am guessing hes sorted it?
Hi Gamble, what did you do to resolve this issue? This is so other members can see what the resolution is in case they ever have the same problem.
