Hikvision NVR Alarm Input/Output
21 Aug 2013
Lincolnshire
I have a Hikvison NVR, Model DS-7608NI-E2/8P that has some alarm inputs/outputs on the back that I want to use.
However, i can't work out how to connect the cables. It didn't come with a green connecting block that plugs in to then connect the cables.
Where do i get them from to be able to use these features, as one didn't come with the NVR.
Thanks in advance.
Attached is the back of the NVR, the green block is obviously the alarm input/output part but assume there is a connection block that should plug into this?
what do you want to connect?
just a door contact so when a door is opened the camera pointing at the door goes full screen, however i'm assuming for the full screen view option it will only apply to a locally connected monitor to the NVR and not over the web interface, which really defeats the object when the NVR is located out of sight in a cupboard.
trying to find a video for you to show you exactly how its done, not sure how else to describe it to you.
